6N2 Rear wiper leaking from the "L-piece"???
I've got the common rear wiper leaking problem but it thought it would be the pipework or joints leaking however it seems to be backfiring from the L-piece that takes the washer water through 90 degrees and towards the jet itself.
I think it mght be because the jet is partially blocked although some water does flow out of the jet the majority comes out of the back of the L-piece from what look like 2 small wholes that were either there all along (as some kind of weird pressure release thing) or have appeared though wear and have some kind of crack which is letting the water out.
I was going to block these "holes" where the water comes from with Araldite or other epoxy resin but was worried that there are supposed to be there to protect the pump (but drown the electrics and mechanics inside the door instead?!?!)
Can anyone shed some light on this?
Apologies for the crap photos, it was very bright and hot and they are out of focus!.
  • Views 865
If you use the search put in 6n2 rear wiper not working-then put well-abused-5-door in the member name filter. Sorry I do not know how to post links but this post should answer your questions.
I have same problem, mine dribbles from the jet and leaks out everywhere else, apparently inside the washe theres a copper tube which stays still as the wiper turns, with this being a weak metal it cracks and so dribbles.... i was told only way around it is a complete new wiper mechanism thing
