6N Amp Location
I'm currently running two amps located on the boot floor along with my sub box. So as you can imagine my boot is practically useless. Is there anywhere that people have fitted their amps to?? Not keen on mounting on the back of the seats.
Any pics would also help.
  • Views 1.4k
under the front seats?
no can you help me and my problem out :)
the 2 threads below this one :D
in my golf i mounted the amps behind the rear door cards so they were out of sight and i still had my boot space
How did you mount them behind the door cards? Pressume you mean on a 3 door?
yea on a 3door i used so metal strips and drilled the internal body work of the golf and mounted them on to that,
i only had 2 small 2 channel amps there so i had a lot of room to play with
You could mount a fake floor+wall, without building the floor up. This way you can mount the amps onto the mdf-wall, and they'll be between the wall and the seat back. Then they aren't visible, and you almost doesn't use anything of your boot. :)
