What primer...?
I've practicaly finished smoothing my bumpers....i just need to sand the stopper smooth. What type of primer should I use before I send the bumpers to the body shop to be painted? Shall I use standard plasti coat grey/black primer,is there special stuff or shall i leave it down to the body shop to prime (at extra cost???)?
The colors going to be Dragon Green.
Angus
id let the bodyshop do it as 2 pack primer is thicker and more durable than rattle can stuff
if you must diy em....plastikote do one called filler primer, use plastic primer on any bare plastic spots first
Edited by steveo3002
put a mist coat of ecth primer on then upol do a good filler primer use that, isnt cheap tho
we use that upol aerosol "high build" primer at work for small jobs coz its quick and easy.
