Sony Xplod 500w Amp
Sony Xplod Amp - I brought this about a year ago and used it for about 3 months in one of my cars since then i haven't used it so i may aswell sell it on to someone who will make good use of it, plus I'm going for the stripped out lightweight car rather than the sound system option!
£40 + £10 for delivery
Heres some details i found off the net:
Forget all that's gone before! The XM-SD14X Sony's STREAM DESIGN amplifier is revitalising the amp world. New features on this gorgeous amp include MOSFET output stage, and 2 large sized choke coils bring maximum power handling and Hifi sound quality to your wheels at all volumes. And mouth watering Blue illumination adds a unique intensity to your nights on roads. This multi channel amplifier also offers a maximum power output of 4 x 100watts at 4 ohms.
Sony XM-SD14X 4 Channel Car Amplifier
Channel Configuration: 4Ch / 3Ch
Line - Low Level Input x 4
Speaker - Hi Level Input x 4
MOSFET Power Supply
Toroidal Transformer
Gold Plated Terminals
DIN 45500 Rating (@ 14 V, THD 0.5 %)
4 ohm: 4 x 55W
4 ohm - BTL: 2 x 65W + 1 x 130W
2 ohm: 4 x 65W
Rated/THD (@ 14.4 V, 20 Hz - 20 kHz)
4 ohm: 4 x 50W / 0.04%
4 ohm - BTL: 2 x 50W + 1 x 120W / 0.1%
2 ohm: 4 x 60W / 0.1%
Maximum (@ 14.4 V)
4 ohm: 4 x 100W
4 ohm - BTL: 2 x 125W + 1 x 250W
2 ohm: 4 x 125W
Input
High Pass Filter: 80Hz
HPF Roll Off Rate: -12 dB/oct
Low Pass Filter: 80Hz
LPF Roll Off Rate: -18dB/oct
Balanced Input Circuit: Balanced Input Circuit
Input sensitivity: 0.3 - 6Volts
Output
Frequency Response: 5Hz - 50kHz
Tolerance: +0 / -3dB
Signal to Noise Ratio (@ Rated Power): 100dB
Total Harmonic Distortion (@1 kHz): < 0.005%
Min Load Impedance/Ch: 2ohm
General
Illumination: Blue
Current drain (@ Rated Power - 4Ù): 30Amps
Fuse Rating: 25Amps x 2
Weight (approx.): 3.1kg
Dimensions
(WxHxD in mm) approx: 378 x 55 x 265
  • Views 558
pm'd
bump
hey, WOULD you accept £40 posted IF u had it saturday??
pm sent
Sold.
