replacing mk5 front wings how?
hi i want to replace my drivers side wing as it has a dent in
are there any fasterners etc or is it just a bolt off and bolt on job?
cheers
  • Views 1k
As far as i can remeber its a bolt on and off job, you'll see all the obvious bolts when you go 2 do it..
lots of torx screws holding on the arch liner, once thats off you'll see extra bolts, when i was changing my wing i had to cut away the anti corrosion coating to get at the bolts, not sure but i'd reckon the 6n2 would be fairly similar :D
hmm decided i cant really afford a new wing this month!
i got mine from a scrappy for €15 :D, when you are doing it be sure you put the front of the car on axle stands, some of the bolts are well tight, take your time to line it up too, nothin sucks more than odd panel gaps :D
