CONVERTING REAR LIGHTS FROM LHD TO RHD
ok want to buy some hella smoked led lights from a 6n2 polo
1. will they fit a MK4
2. how do you convert them from LHD to MOT Pass RHD
any help would be appreciated
  • Replies 16
  • Views 8k
you will get a better response in the technical section
I'm sure one of the mod fairies will move it!
The only difference between the LHD and RHD tail lights is which way round the foglight & revers light is. - What you need to do is break out the red reflector on the passenger side - and fit a red bulb to the bottom one of the drivers side - job done!
or better still they will just reply LMAO
just change the bulb on the drivers side to a red one and youll be ok. youll probably still get them as an advisory for the MOT, i did.
so by breakin the reflector that thn becomes the reverse light right??
or you could do it properly and remove the pin for the reverse light on one side of the loom and swap it for the fog on the other side. No need to smash anything, just re-routing wires.
that easy to do within a day an howd you do it?
Thats still a fail as the foglight has to be on the drivers side or in the middle of the car - not on the left!
so really i buy them break the reflrector stick the reverse bulb in that done an put a red bulb in the driver side 1 right??
Yep!
Or do as most people do - rattle the originals in for the MOT!
But it's Euro? I thought Euro cars were exempt from everything except the yearly scene tax?
cheers everyone soon as i get them pictures will be up
I'm sorry but, is it not just easier to put the standard lights back on for the MOT?
depends would u rather break a reflector an put a bulb in or...
cum to a mot unscrew the lights unplug all the bulbs take the lights off find old lights put them in plug all the bulbs in thn rescrew pass mot unscrew the lights undo bulbs take lights off find the new 1s screw in screw in bulbs make sure they work
hmm to me seems alot easier to convert
Yep!
x2
Wouldn't police possibly stop you if it isn't converted to rhd or not? if so it is worth the hassle to change them.
