removal of rear wiper
I want to remove my rear wiper on my 6n, but keep the motor in place incase i wanto put it back on. How's this done? I'm going to stick a rubber bung in also
  • Replies 12
  • Views 1.9k
just take the whole thing off mate, its easy to put the motor back in.
if you just take the wiper off it will look stupid as theres a little bit that sticks out.
I'm wanting to de wiper mine, but scared about accidently flicking the stick to do the rear wiper.
dont want fluid pissing everywhere or if yu tie it up i dont want the tube to pop off somewhere else in the car and pis everywhere there.lol
i took mine off yesterday :) very easy job on mk3 :)
me and higgo done his yday aswell. its easy, gota take the whole thing off tho or it will look crap like dilz said.
just bend the pipe round and tape it up, u will know not to use it cause u took it off lol. just keep all the bits together incase u wanna put it back on in the winter.
ok yea i suppose.
what size grommets do i need?
heard there 25mm?
cheers
i dont know about grommits. just get a wipe blank, cuz the glass is a weird shape where u take the wiper off. theres some wiper blanks on here for sale somwhere, i think theyr around £7 posted.
or do it yourself, just get the original blank shove a 10p in the hole, filler it sand then paint,
its what i did and has come out quite good
is it a 25m grommet the guys?
gonna do it tomorrow.
i did a how to on this, never got stickid mind, try searching fro me (POLOMON) in this sub-forum it may still be about
Yo does anyone know this guy that sells blanks for a mk4.
i have just de-wiperd mine and the grommet sticks out loads and thought it would look the doggs flushed.
cheers
flip up wiper cover and undo the 10/13mm nut and remove wiper, undo the remaining bolts and fixings on the outside.
inside the car on the boot panel remove the phillips screw in the handle and pop the cover off, you will see the motor held in with about 3 10mm bolts, undo these and carefully remove motor from the car, disconnecting elctrics at the same time.
remove the washer jet at the bottle up front is best and plug hole or just kink and tape the end of the pipe and remeber that you took it off and cant use it.
easiest way to fill the blank is get a 2p in the hole and chuck some resin in there to hold it in then take a 50mm bolt and resin and glass the head into the back of the blank, when dry filler and paint the front and put the bolt through the hole left by the shaft (hehehe i said shaft) fit a nut and large washer and gently tighten then it will never come unstuck or be nicked by scum :)
any help?
I like my wiper, why you's getting rid of yours?
What if it rains -_-
