Rear washer not working
Can hear the pump spinning and theres water coming out of the front so theres water in the bottle.
Any ideas why water won't come out of the rear.
cheers
might be blocked.
stick a needle in the end of the nozzle.
Before it stopped working was the water spray sweeping or just squirting in one place? I noticed mine had started sweeping. I took the rear panel off I removed motor assembly and took it to bits, the spray tube that would normally stay still had broken and the water had filled the motor with water also there is a circuit board which controls intermitant and a set of gears all of which were completely fooked after a nice long soak. After several attempts at fixing I had to give in and buy a new one £90. IIRC, VW only aswell :shock:
P.S. my tube had disconnected next to rear seat on pas side but mine was 5 door don't know if 3 door is the same. :?
If you use the search put in 6n2 rear wiper not working-then put well-abused-5-door in the member name filter. Sorry I do not know how to post links but this post should answer your questions.
cheers
Wrong way round :lol::oops::oops: but any help???
