new wing. underseal or not?
have a new wing to spray up.am not bad with the old rattle cans,was wondering what have people used on the inner side when respaying?
1. spray up as outer?
2. use hammerite/smoothrite?
3. primer and lashings of underseal?
any info/tips would to well received.
cheers
  • Views 1.3k
i would personally paint as normal then go over with some stonechip/underseal yeah or a decent coating of waxoyl unless your running arch liners then you should be fine with normal paint as thats all they have to start with
cheers for the speed reply !
am off into garage to rattle some cans
Tbh I got a near enough new wing from the scrap yard which was originally white, took it home and gave it some wet and dry to get it smooth and clean, cleaned the inner side of the wing from dirt and softish gunk, and then painted on with a thick brush a nice layer of underseal. Not sure if it was the correct thing to do but it's dryed and will protect it I hope. Then a couple of thick coats of primer to the outside.
have got arch liners,so will use stone chip on the inners as i have quite a bit of that stuff
