I've dewipered the polo
to stick the black cover back on?
whats best?
cheers
shaun
  • Replies 12
  • Views 1.7k
pm gharbud, he made some covers to fit over the hole left behind
Edited by g40jon
superglue ?
Heard a few people using a 10p piece to fill the gap on the plate, filling over it flatting back then spraying and a coat of lacquer.
if you just use supergle to stick the cover on. it wont be waterproof will it.
dont want anything leaking.
cheers
i used trim repair tape (can be bought form halfords) , but i know someone who used silicon... :thumbsup:
Silicone Sealant
trim repair, whats that dude?
where abouts should i be looking in halfords?
cheers
shaun
shit its just started raining. hoping for the best untill i sort it out.lol
please dont leak please dont leak. :lol: :lol: :lol:
shove some duck tape over it for now then?
its stuff you use to stick side strips e.t.c back on good stuff and in the erm, well in my local it was next to allt he fillers sand paper and pains. its called trim repair tape, in a green box with the roll sticking out the side.
k dude, sweet.
will pop down in a bit then.
and yea its duct taped up at mo.lol
cheers mate, great help.
hahaha ok cool, good luck with it then, and the wiper pipe... if you shove a screw in it and kink it over and cable tie it around the screw and the other bit of pipe where you kinked it youll be fine it wont leak.
if its really a problem remove the pipe at the washer bottle side cut a small section off and do the screw and kink thing there then if it does leak its only leaking into the engien bay not the bootlid.
ok bud, good idea.
cheers mate
i always glass a bolt onto the back of mine to make sure it stays on then run silicone around the outside edge to seal it all up nice and safe then :)
