Where to get matt white paint?
Anyone know where to get 2-3 litres of matt white paint for a car from? :?
any site on internet or place to go for it, never had to buy paint in litres before, so any help is appreciated
Ben
  • Replies 8
  • Views 2.1k
Ben
you can buy a matting agent just add it to your paint
white primer...? that might be cheaper not sure how resistant to water it is mind, i always thought primers absorbed water ahh well :p
The primer's underneath the topcoat to aid adhesion. So I can't imagine it'll be much use as a top coat.
primer as a topcoat is pretty bad (says he:) ) you can run it just cant be polished at all and also all the dirt builds up in the pores of it. make sure you have a good base coat underneaths thats waterproof say and existing car topcoat then go over the top with it. yeah matting agent can be added or just buy white primer a hole bunch cheaper bud
so would white primer just look pretty much the same as using matt white?
might aswel get white primer if it does
yep but will dirty quicker and wont be as easy to keep fresh
matt white is gona stain and look rank pretty quick...not sure if thats the effect you want?
any paint shop should be able to add matting agent to any colour ....or get b&q to mix some eggshell dulux if its a old rat job
http://www.jawel.co.uk/
They can mix up anything. If it is going to be matt, you may as well get synthetic as well. Cheap as chips!
