arch work
would what I've done be ok, i.e. will it flex?
cause any problems???
need to be looking near the bottom of the page
bear in mind more fiberglassing and bodyfilling needs doing on it
http://www.clubpolo.co.uk/forum/index.php?showtopic=112192
cheers :)
the inner arch and wing don't join there. It's not really structural I would have thought it'd be ok. If you are planning on doing the same with the rear arches though that's a different story, they'll need to be properly welded.
i wasnt, i was planning on taking front arches and welding them on as you say
thanks for the help mate
feel better about it now :)
fair play for having a go but the arch will only crack if all your doing is using fibreglass and isopon, it just crack under the paint, I'd either look about a new wing or find a repair panel wheel arch to put in it's place, a Talbot sunbeam has a wide rear wheel arch if I remember right?
Edited by areofall
