mk3 smoked headlights
Just a little question, really, i was at prept/players last week at Brands and I saw a red mk3 coupe with smoked headlights and indicators. have seen these before on a different car. Any ideas where to get them?
  • Views 954
make them yourself or if you can get me a set i should be able to make them for you bud
Yeah they are easy enough to do yourself. There's a guide on there somewhere!
Basically remove from car. And remove plastic bracket, place entire light in the oven at about 200c. Leave for 10mins, them try to lift the lens off the reflector carefully, if it sticks, its not been heated up enough!
Leave to cool.
Paint the non reflective part in high temp paint. Leave to dry, use silicon to seal lens back onto the reflector then put back together!
That easy
