removing dial needles
i was going to fit white dials in my 1996 polo. took the clocks apart and now cant get the needles off. i tried the gentle approach, with pliers, so not to break them and no luck so pulled harder and still wont come off. its starting to make me think they arent going to come off. anyone no for sure if they do or any easier way to get them off? thanks for any help
I used the two spoon approch. Basicall put a spoon either side of the needle and push down. it should lift the needle up and off easy.
Make sure you apply equal force otherwise you'll break the plastic and the needle then wont stay in place when you go to refit
if not a fork is as good place the centre of the needle in one of the forks prongs and then ease off :) simple
