numberplate screws wont budge
my rear numberplate is looking tatty so i tried to get it off but the screws have got rusty and i cant get them off.
does anyone know a good easy way of getting them to budge?
thanks
  • Replies 12
  • Views 1.7k
sand them down with a finger file or some sort of power tool (Y)
I've just had the same problem, will new number plates crack if i have to drill holes to fit them myself
I took off the tailgate trim & did them from the inside with some grips
If you are putting new plates on, break the old plates off around the screws and undo the screws with pliers\molegrips.
New plate won't crack if you drill it. Drill a 5mm hole from the back.
Have done, cheers
i was hoping i'd be allowed to break something, hehe
I have to do this at work quite often - Snap the old plate off and use mole grips, then stick the new plate on with sticky pads. No point in drilling them anymore, sticky pads are tidier and just as strong if you clean the surfaces properly.
also no need to drill new plates if you get a hot screwdriver and burn it through the numperplate, this also seals the plate and protects it from dirty water getting in and seperating the layers.
Other way is just drill through the old screws.
Taped on plates look far better in my opinion.
I had the same problem and i just drilled into the screw with the right size drill thats easy enough isnt it.
undo the screws with mole grips is the best way
they aint tight
Taping your plates on looks nice until some git wants them to get some petrol. I round the head on the screws so they can't get them. It's been tried too many times.
