doors
Hi,was just wondering if mk2 doors fit on mk3s and still look the same....just curious after been on ebay and seen a door for a mk2 but would fit mk3.
  • Replies 10
  • Views 1.4k
Yep
Only the door cards (and rubbing strips?) are different but everything is interchangeable.
are the door cards much different to the mk3?
Yes very much so!
we will scrap that idea then.
cheers.
Edited by mucker
Why scrap the idea? Dont you have the later door card to fit to the MK2 door?
Its at that point you'd realise the later door had a side impact bar in it..
Not all Mk2F/Mk3 doors have impact bars Mikey
I dont know if any should have.
I remember an article in the early 90s about some bird in a crash on the Autobahn,in her new Polo. It was a silver breadvan. The fire crew took ages getting her out,as the impact bar had acted like a door bolt and pinned the whole crushed mess together.
The picture showed the rear quarter panel all cut open,exposing the end of the door bar.
late mk3 have - k reg on (approx)
TBH Mikey, calling them door bars is a bit much - it all sounds really tough and mean! :lol:
The truth is, its a weedy bit of thin wall tube that whist improving the integrety of the door frame, don't actually do much in a side on impact!
I'd rather not be involved in an accident in any sub 6n Polo. Flimsy is a word that springs to mind! (However, only on a parr with everything else in its class/age bracket).
A Calibra cut me up a couple of years ago,swerving to avoid an idiot,under heavy ABS braking in the wet. I skidded into him.
The only damage to my MK2 Polo was a dent in the tip of the front wing,slight warpage at the line from the arch. But the impact into the Calibra bent its rear panel,quarter,and kinked its rear arch.
I needed a new wing. The Calibra,which drove off,was probably a write off.
