Sliding Sidemount Bucket Seats..
I've spent a good while rooting about on the internet/Club GTi and still haven't come up with a conclusion to my problem. Brain is approaching melt down... :retard:
I'm keen to fit Recaro Pole Position seats + side mounts onto a slide (and possibly tilt/height adjust if available) subframe, so that I can retain a little practicality. My car is currently used on the road but I plan on attending track days in the future. Perhaps further down the line the car may become less road friendly/more track orientated...
To make life easier and the seats safe, I was keen to find an off the shelf solution that did away with/minimised the need to weld/fabricate.
Most subframes on sites like sportsseats4u seem to say "for base mount only, not suitable for side mount." I'm keen to find a solid answer before parting with any cash and experimenting with parts.
Whilst I am sure it has been done I can't think of anyone having fitted these seats into a Mk3 Polo that I know of. A saving grace is that Mk3 Polo seats can be interchanged with those from a Mk2 Golf/Corrado so hopefully there will some Golf/Corrado owners who can provide some first hand experience...
Current Parts List:
Recaro Pole Postion (yet to decide on ABE or FIA): http://www.ononrackperformance.comPOLEPOSI...OUR%20BLACK.JPG
Side Mounts: http://www.on-trackperformance.com/Brackets_aluminum.jpg
The Subframe Issue...
Below is a picture of a Recaro Subframe for a Volkswagen Polo '78-'94 from edworthys...whilst it doesn't specify I presume it's for a base mount seat? This is probably a generic photo as well so I am inclined to take it with a pinch of salt...
These Recaro Double Locking Runners are also available but I'm not sure they'd be much use...I presume they'd need to be fitted to something solid like tubular seat rails?
So that's as far as I have got with my research and I was wondering if anyone could point me in the right direction? There is of course the option of biting the bullet and having tubular seat rails fitted, but this would require finding someone with the required fabrication skills and putting my faith into a fixed seating position. Any help greatly appreciated...
Couple of pictures of what I'd like courtesy of some BMW owners:
Edited by Tav
  • Views 4.2k
This probably doesn't help you at all as it has been fabricated but this is what I am using.
Its being used with a base mounted seat but there is no reason your side mount brackets won't attach to it.
Tav,
I have literally just fitted up my side mounted Cobra Suzuka's. A similar seat to the Recaro you talk of.
There are several problems with fitting side mounted seats in a mk3, there are also several things to take into consideration.
The seats must be in the correct driving position, the harnesses will need somewhere to secure to and they and the seats must be mounted very securely.
The first is that no company seems to do an off the shelf subframe for side mount (fixed back) seats, mainly because their design is for motorsport application, which usually means fabrication is not a problem for a team or competitor. EDIT: I think i remember seeing 'Pinches mk3 rally slag running some Magnums on subframes but i'm not sure if they were off the shelf!?
The second problem is seating position. Obviously this is hugely important. Due to wanting sliding seats I obtained a pair of universal slider rails from Cobra (which was in fact still for under-mounting recliners) so i modified the connecting bar between them so they were wide enough to reach each side mount. Problem solved.
The third problem is how you are going to mount them in the car. I briefly looked at the bottom of an original seat with the intentions of stealing the frame or something, that was before thinking 'no chance'. The next step is to look at mounting in the car. If you are intending to use the car in any form of official motorsport then the scrutineers will want to see correct mounting. A copy of the MSA handbook will provide all the information needed.
I decided that the only real way to mount them was to weld in two cross members in the form of 2x1" 3mm wall steel box section.
The pictures below shows the sections in welded in place..
From the pic you can see the sections welded in place. I removed the 'bridge' for the original seat front pin by drilling it out as it was in the way. You can also see how i have positioned the harness mounting plates, utilising the original seatbelt thread on the outer chasis rail and welding a plate to the exhaust tunnel and to the front cross member for the '5th' strap. This is just how i have chosen to mount the seats and harness plates. Others may agree/disagree.
One thing to ensure though is that the seats you select are not going to be oversized for the car (as its not a big space in there) and that you will definately be happy/comfortable with the position.
Another thing to take into consideration is the height that the seats sit at. On the lowest set holes on the cobra mounting plates my seats sat to high with the the slider rails attached so i am now having to go without the luxury of sliding seats but this is no problem as i am happy with the driving position!
Hope this helps. If you have any problems or want any help just shout!!
Jez
Edited by jez1272gt
Cheers for the pointers Jez!
My set up is similar to Jez's, just had 2 bars welded across after cutting back the original stuff.
My bucket seat is a Corbeau Pro Series XL :D so its a bit tight but fits. I have a Corbeau GTS seat for my passenger on a base mounted subframe if I want to put it in the car.
In terms of adjustment for mine...my subframes can be adjusted at the side and bottom.
Edited by Maxeh
Tav,
Jez
take note that your crutch strap eyelet is in the wrong place and should actually be on the rear bar
Not sure if it will help you out, but it might be a solution for you. I've just fitted a pair of Impreza WRX seats to my coupe using the base mount frame as shown in your pic (and it doesn't look like a polo frame as you say). They fitted a treat as I wanted bucket seats without the costs. £50 for runners and £50 for the pair of seats. But as the other guys say, looks like you'll have to weld in some brackets as I looked everywhere to find another solution to mounting my seats without using some off the shelf custom bases.
Ah that would probably make sense LOL. Wondered why the crutch strap had such long adjustment! Thankfully its easily fixed - cheers pinches!
