De-bedging Polo...6N2...
I've used the search function and I've read that you need to use boiling water...pour it on top and then peel the badges off
Whats the best method tho' ?...using boiling hot water and peeling the badges off ?
or
using a hair dryer...to heat the glue up and then use dental floss put behid each letter or whatever and keep rubbing it back and forth until the badge comes off ?
also whats the best way to get rid of the gunk thats left behind ?
kinda stuck as to what the best method is...thats why i haven't de-badged my polo yet (want to take off the "polo" badge and the "1.4" badge)
cheers for any help
  • Replies 13
  • Views 2.1k
i used hot water and a credit card....dont mind doing it for you...dnt live too far about 10 minutes...
Use hot water not boiling. Boiling water could damage the paint.
OOOO.. my 666th post :evil:
Edited by B-shaw
EEEEEEEEEEEEEVIL!!!...lol...how easy is it to debadge ? I've been puttin it off for so long because of the SHIT weather down in nw london...is it better to use the hot water then ? rather than a hair dryer and heating the letters for like 20 seconds or so ?
hairdryer and card works best imo
and bug/tar remover after
i did the taped up butter knife trick and petrol on a rag, worked perfectly not such a good idea but worked for me :D
get hold of a heat gun!!!!
i did my whole car in about an hour and a half and its totally clear
heat up the strips/badges and gently prise them off...then heat the sticky stuff thats left and just rub at it with your finger - comes off a treat.
did you only take the badges off on your car ? and how long did you heat up each badge for ?
Edited by SoniC6N2
No...I've destripped my car and debadged it..heated the badge up quickly..30 seconds or so...prised up the badge with a credit card...then applied heat into the gap id created with and gently pushed the credit card further in.
hope this makes sense, just be patient and use an old credit card (it will probs melt lol)
de-badging is done...used a card and warm water...came off well easy
Before:-
After:-
Edited by SoniC6N2
Gonna do mine on Wed actually.
And wont be doing it like I did on my first car....knife + lots of hacking = nicht so gut ja.
does it not leave any damage or scratches to the paint??
there was no damage or scratches left on my one, just remember to take your time and be careful
Edited by SoniC6N2
The place where I park my car is about a minute's walk from where I live, so I had nowhere to plug in a hairdryer and hot water was impractical.
I removed my bump strips (which I believe are attached in the same way as the badges) by using the dental floss method- just saw back and forth with the floss until you get through to the other end.
I found that once I got it started, it made things easier if I wedged something between the strip and the door to put a bit of tension on the adhesive. This made things go a lot faster and also snapped the floss less often.
I wrapped the floss round a couple of fingers and held the reel in my other hand, so when it started to fray I was able to feed a new section of floss out of the reel without having to stop sawing.
his method doesn't damage the paint whatsoever, but does leave the sticky black stuff behind. I just pulled it off bit by bit, which took ages but eliminated the risk of scratches. If I'd been able to heat it, it would have been loads quicker.
