G60 green injectors + Chip
These have been fully rebuilt with brand new filters, spacers, pintle caps and o rings in all 4, then electronically and pressure leak tested, ultrasonically and chemically cleaned. Then the spray pattern tested and flow rate matched. Pretty much new. Same as what PSD used to sell, good upgrade for a G40 running more boost. £80 delivered, or £145 delivered with a anti lag map to suit the injectors.
  • Views 277
Bump
