Rear Fog Light On Wrong Side!
Just had the first MOT for my Polo and it failed because the fog light is on the wrong side of the car. It should be on the drivers side and the rear but its not, its on the passenger side.
I'm guessing my car is an import? The V5 states that it was 'Declared manufactured in Aug 2005'. I've got a seperate light installed on the back but i was hoping to switch the reverse light and fog light around, to rectify the problem.
Any advice on 'How-To' would be brilliant!
  • Replies 16
  • Views 4.5k
swap lhd for rhd
What??
What??
european cars that drive on the rigt hand side of the road, have the rear fog lights on the lefthand side of the car... so you need to get a light from a uk car that drivs on the left, hence the fog light will be on the right had side of the car (drivers side)
hope that helps.
I wondered if i could swap the wiring around for it and then change the bulbs.
might just be easier to buy a new rear light cluster for a tenner from a scrap yard. save you hacking into the wires.
plus, you might find the lense is coloured, so swapping the bulb wont make a difference. check the bulbs first before u cut the wires if you are going to go down that route.
Lens isn't coloured, no matter what i do thought i'll have to re wire even if i have a new rear light.
i didnt think it mattered what side it was on lol
Just fit a UK spec foglight unit (offside),and have symmetrical lamps. Add it to the foglight loop so both fogs work,or at least extend the wire to the offside,as that side has to work for legal reasons.
You wont have a reverse light,but you dont need one.
trust me you need a reverse light lol! just doesnt come into the m.o.t test thats all
wire up some spots facing backwards, thats what mine are and the MOT Tester didn't bat an eyelid. My reverse switch and all the reverse cabling is well and truly messed up, cant replace it without it snapping so came up with this on a manual switch I've been looking for a LHD rear lights for the mk3 so that i can get rid of my useless reversing light and fit dual fog's. as mikey says all nice and symmetrical.
Take a look here and you shall see.
http://www.clubpolo.co.uk/forum/index.php?...st&id=23644
Edited by Cymro
What i was considering is swapping the bulbs around, as the lenses are not tinted. Then i would re-wire the light up with the correct switch.
Having trouble getting rear lights off.
Can anyone help?
Hey all i managed to get some new rear lights for my Polo, but i need to swap the wires around but i don't know how to remove them from the black plastic holder which you connect to the lights.
Do i just pull the wire out i need or will i split the wire, is there a way of removing them from it.
Any help would be ace!
you'll need a special tool to remove the pins from the connector or you might be able to do it with a very small but long flat blade screwdriver. Prob easier to just tap into the wire (i.e. cut it and connect a new wire to the other side of the car). As Mikey said, you don't need a reverse light (although it's beneficial to have one so people know to get out of your way!).
What tool is it, could i use tweezers, or could i end up damaging it? Is it a spade connector?
Edited by thetinman
a tool specific to removing the pins from whatever type of connector it is! Maplins might have them... doubt you'll get anywhere near it with tweezers, as I said a very thin, long screwdriver might do it. Yes of course you can damage it. I'd just cut the wire, you are going to have to join another wire on to run to the other side of the car anyway.
