VAG com
Had a lambada sensor put on by myself yesterday as when it was scanned by a friend it came up as a fault. so i go to my local garage to have it cleared today and he asks for the year... i say i dont know but its N reg. he says he needs to know the 10th number of the Vin code so i go under the bonnet with him and he does a rough count and comes up with "Y". he puts it in the scanner and it comes up with loads of different engine codes. now mine is AEV but it wouldnt come up with it for some reason so he goes with "AER" and it sure enough comes up with "HALL SENSOR" except this time it comes up with HALL SENSOR G40 0****" i say well its not a G40 thats for sure but he says it doesnt mean its a mk3 g40 and that its jsut part of teh code.. So he tries clearing it and it wont clear. he then turns round and says basically your part is faulty as its just saying no signal from the hall sensor or your ECU is buggered. he asks for his tenner so i give it him yet I'm no better off than before.
is the fault not clearing because hes used the AER code to begin with instead of the AEV code or is my ecu bollacksed?
  • Views 1.5k
surely it means you need a new hall sender? Which by the way, is the same thing as a cam position sensor.
Mine (albeit a mk3 AAV) has that fault permanently too. Have always ignored it because it doesn't come back when the engine is running, only when shut off when the hall sender wouldn't be giving a signal anyway. It's been fine like this for a good 2 years now (since I got vag-com so it may have had that fault for much longer).
Give me a shout when your free Jay, and I will try and meet up with you!
I'm in work tomorro, but free on sunday!
have spoke to a mate who works in a garage and he says that the car wouldnt run if there is a fault with the hall sender so it must be the wiring or the ECU. still wont clear either. its just behind the dizzy cap on my engine bay according to where my mate pinted to. any ideas guys?
well deff if the cam senser fuked you are car would run lumpy an wouldent pick up very well so dought if its tht if he put the wrong engine code in then he wont be able to clear codes because it might be a differnt ecu so wont work id ask him to go in threw EOBD because u dont need to tell it wht engine its got in it it will figger it out it self since i think about 95 all cars legaly have to have this on them failing tht go to a diff garrage like mine ware people are trained to use diagnostic equipment ha ha
saying that tho i would have the cam sensor out an clean jus wipe it of thay work on magnuts so thay catch a lot of metal shit lol jus wipe it over thn see it makes a dif but thn u should sitil be able to clear codes he must not know how to use his diognostic equipment i say
Edited by carsbabesbikes
The car run's quite lumpy and there is a constant missfire but only very faint. it never picks up well at all either and sometimes the revs tend to drop slightly and the car will cut out and then carry on occasionally. i haven't got a clue what the deal is now, although I've been another garage the guys there couldnt find my engine code "AEV" when they told the snap on fault clearer the 10th digit on my VIN.
does anyone know how to replace the hall sensor and also how to find it?
any ideas as to why it will not clear? I'm drawn towards the fact that the garages are trying to clear it through the wrong engine code section but i know very little about these things.
the s apparentlkey no signal from the hall sensor and this is why it wont clear yet the car seems to run and I'm told it wouldnt run if the hall sensor was broke. the first garage i too kit too seem to think that a hall sensor is a lambada sensor and this is what needs replacing.
i keep getting opposite answers from wherever i go to for help so i am lost as what to do.
