wheel bearing
hey chicks and dudes
any one know how expensive it will be to change wheel bearing on a
1997 P reg, 3 door hatchback
thanks
  • Views 858
Depends if you do the work yourself. I spent £15 buying the back 2 last year and fitted them myself. Was quoted £60 though at the garage to do one of the front ones.
most likely ill be doing it
any tips on how you have to do them
as there any compresion needed mate
if its the back 1s u doing u wont need any pressure, and they are only about 8quid each. they ait that hard to fit just take out the split pin on the drum and undow a 17mm nut (i think 17 I'm not 2 sure) and then a washer then the drun should cum off exposing u to the wheel bareings. as long as u remember wich order they all came off u should b fine.
but the front 1s will need a hydrolic press. hope that helps.
LEE
wiked mate thanks
