Would all this stuff be compatable?
Well Id just like to say Hello as I'm new to the forums and found them to see if I could get a slight idea on fitting a sound system to my beloved Polo (its a 1 litre, 3 door P-reg just incase you were wondering.)
Now I want to upgrade my sound system from the bog standard stock poop which has been in since it rolled off the production line, but I'm not too sure what combinations will be compatible, I'm looking to spend about £500 on a new head unit, component speakers and a sub and amp deal (sounds like a squeeze I know) and I've sourced these:
Head Unit
Component Speakers
Sub + Amp
I was wondering if someone more experienced than me could have a look over my possible purchases and check I haven't had a mere choosing them, if I have could I get some better recommendations.
Much appreciated,
Dan
  • Views 834
should all work together. i think... but if i was you i would get a 2nd amp to run the comps... but have a word with the guys at base junkies, they built my boot build and i thaught they where very good... they will be able to help u out
Yeah I thought about an amp for the comps, I find that caraudiosecurity is cheaper than bassjunkies.
I've also went for a Vibe active sub box with an amp built in, cos I'm lazy :p
