will a hk manifold fit and hh??
yo any one no if a hk manifold fit a hh engin ?? inlet and exhoste?????
thansk lee
  • Views 1.3k
Exhaust setup is a bit different. Both manifolds fit but it leaves you with a problem: The HH head has exhaust outlets on the inlet side, for heating the inlet manifold, so you need to block these. When I put a later inlet manifold on mine I did the headgasket at the same time (I put a thinner metal one on to increase the compression ratio) While I was having the head skimmed I got the machine shop to put metal inserts in the holes to block them up.
The exhaust also has a pipe going to the underside of the inlet manifold. You will need to remove this and block it, or preferably use a later exhaust.
mine dont have that little pipe that runs for the exhaust 2 the bottom of the carb doh ??
any pics of your engine setup?
il get one tomorow dude
for all angles
its a derby gls v reg if that helps you any more ??? for now
I think the early hh engines might have a water heated inlet like the hk so if this is the case it'll save you alot of hassle. :) Will know for sure when I see the pics. :D
