polo cl gt MK3 NOW BREAKING NEED IT GONE ASAP
it has moved on a bit from that last pic.
has the gt engine fited and running altho it does need the gt pump.
has got the gt/g40 rear beam g40 front brakes, front and rear braces, powerflex bushes on the arb, godridge hoses, have got the 4spd box fitted to the gt engine atm but it does come with the gt box as well along with the 1 liter engine, phillj 80mm kit stock steel wheels smoothed rear boot. painted in a fetching nato green lots of spare paint. black bonnet have got rid of the catch using bonnet pins and hydrolic lifts. huntsmaster buckets nice to sit in, big 4 in one gauge rev-oil press-oil temp-water temp not wired up. f1 style mirrors with bases, decat pipe. and a side exit shotgun exhaust. and a dknight scuttle cover,smoked headlights and indacators. prob a lot of things I've missed out.
NOW BREAKING NEED IT GON ASAP SO PARTS WILL BE CHEAP!
Edited by eskimo_god
  • Replies 11
  • Views 1k
BUMPY!
BUMPY!
Where abouts are you?
Rich
PM'd :)
Edited by Olly S
hi m8 how much you want for the exhast and where bouts r u . pm me with details if poss
were are you how much for headlights (smoked)
can you sort me out with the rubber window seals off of the doors??
how much posted??
cheers Tom
If you're in a rush then would you consider splitting the engine? And is the ecu chipped or stock?
How much for:
GT/G40 rear beam
G40 brakes
Also where about are you?
Any chance of any of the bove posted?
Mike
still got the gt gearbox????
where abouts are you???
How much for the seats?
Whereabouts are you based?
