bumpstrip removal?
how many of you have de bumpstriped your 6n polos and removed paint by accident.
I really want to as it would look alot better, how ever some of the paint is badly damaged and I'm afraid that i may be very weak.
any opinions?
  • Replies 14
  • Views 1.4k
i have removed mine, there was abit of paint damage :( but sure if your more careful and make sure the sticky bits are heated up, should come off fine
Heard somewhere dental floss is good to get behind it to take it off?
yeah i can imagine that would work well, i am a bit worried tho i dunno what to do...
you can always stick um back on haha
that would be an option i guess.
lol check out shaun fraziers post on this...he took off a nice big chunk of paint lol (sorry shaun)
be patient and take your time and keep the sticky stuff hot....personally i used a heat gun rather than the hair dryer job as it produces more heat.
good luck
sean
Don't pull the strips too far away from the body or you'll find the paint will bubble. Keep it close to the body and use a credit card/ dental floss to slowly cut the glue away.
has any one tried fishing wire? surly that would be better then dental floss?
or a guitar string
I used a credit card and mine left no damage. whoop whoop
I used a heat gun to heat up the glue and just gently pulled the bumpstrip away. Then alcohol and t-cut to get the remaining glue off then some polish over the top and the jobs a goodun :)
white spirit removes the glue nicely
youll need to get the buffing machine on the go after
yank it off with you are hand and then use a fudge wheel
i used some plastic banding wrap from my girlfriends work that worked a treat and i didnt use any heat but the bread van mouldings ar pretty hardcore
Same here... mine got a bit hot though, T-CUT got rid of the orangey residue and job's a goodun!
