white g40! mint!
I am interested in another car which i may or may not be able to get my hands on so i need to see what interest there is for my car so i'm putting out a serious feeler......if your interested please take a look, drop me a text or ring me and i will answer any questions...i start a new job on monday so i may be unavailable at times but leave a text with a little detail and i will ring you back and answer anything. i will give confirmation to wether this car is up for sale for sure in due time and dependant on interest...if your interested let me know.
Car comes with original plate NOT G4 0PY
Make:
Volkswagen
Model:
Polo G40 (genuine)
Year/Reg:
1992 original plate J987TPY will come with this plate not the one shown. the J plates are original dealership fitted ones.
Mileage:
141700k
MOT:
January 2009
Tax:
6 months
Good points: original G40 in white. original wheels fog lamps, tilt slide steel sunroof etc.
I have had this car about 3 years now and have spent thousands of pounds on genuine vag parts for it. it is driven daily and has had all the right parts changed including another charger rebuild for safety sake 12k ago and a water pump and cam belt both genuine vag within the last 1k even though it didnt really need it...oil changed every 3k, always warmed up before full boost. please see the list of stuff below and if you have any queries please ask or text me.. the car drives so nice and don't be put off by milage pretty much everything is brand new since my ownership. rolling raoded just after main overhaul @130bhp graphs to prove this.
Fitted this summer within the last 1-2k vag waterpump/timing belt. brembo discs and pagid pads and two new toyo tyres up front.
only mods are:
golf rear door handles without key holes with armour door plates
H&R cup kit 60/40 (New vag top mounts fitted too)
polished rocker cover
new braided charger oil feed
Gladersiete roll bar blocks
PSD braided brake lines
Vag de-cat pipe
Full blend charger rebuilt 12k ago.
gearbox rebuild by jp race around 12k ago
fan switch mounted in blank in the dash using a rear screen switch fitted professionally
this is gonna be long but in my ownership, 40k its had the following:
95% from VAG or if not they are the same items as vag would provide i.e. bosch.
fuel pumps (both and both from vag)
injectors
fuel tank (waxoyled)
hall sender (bosch)
coil
vacuum hoses
new shells and bolts bottom end
head rebuilt with new valve stem oil seals
head bolts
waterpump (vag and less than 1k ago)
timing belt (as above)
thermostat housing and associated parts
new oil seals and gaskets everywhere, head/rocker/cam/crank etc etc
knock sensor
lambda probe
blue temp sensor
black temp sensor
oil dipstick
earth leads
ignition leads
dizzy cap
rotor arm
battery
air filter
clucth kit
clutch cable
boost pipe jubileee clips/nuts bolts/ everywhere
brake lines replaced at last mot with genuine plastic coated steel vag ones
g12 coolant
radiator
fan switch
oil changed every 3k miles without fail
vag exhaust mounts and rubbers
mid section is almost new vag.
charger belts along with charger rebuild 10-12k ago standard pulley used all its life so has plenty life left in it.
Brembo discs and pagid pads July 2008
full brake fluid change done MOT time along with new Vag steel brake pipes (January)
engine rubber mounts (powder coated mounts)
rear wheel bearings rear shoes
vag rose jointed steering arms (both sides)
the following parts have been powder coated
fuel pump bracket (fitted with new rubbers and bolts from VAG)
charger mount
rear engine mount
tunnel brace
Interior.
original apart from steering wheel which is an italvalanti one.
seats rebuilt with new cables and runners
slight fading on rear seats but no broken cables, rips or tears or damaged sponge whatsoever!
original throttle powder coated satin black.
vag mats
new leather gear gaitor
no radio equiptment just a vag stereo storage compartment
central locking from key fob ( has rear golf handles which have no key hole and armour door plates fitted)
Exterior
Renewed boot vinyl and supercharged badge and boot plynth bolts, washers, lifter dampers and number plate bulbs.
gearbox rebuilt by JP race about 12k ago with new bearings and seals and refitted with new vag release bearing and vag gearbox oil.
The car is mechanically spot on and drives amazingly. it has a very slight miss fire on morning start up when the outside temperature is very cold. I have checked absolutly everything to try to fix this but I'm being really anal as it clears within seconds and the car drives faultlessly but i'm trying to cover everything here.
I am a complete fanny about this car, any amount of money is spent to keep it right!
i have a wallet of all the reciepts which i dare not count up
Bad points:
back box is non genuine g40 and will probably only last another year
With the body work
I'm going to be more critical than necessary.
The rear corner pieces below the lights have started to rust and need sorting. there is a couple of small dings (minor)
there are a few small bits here and there. but the car overall is structurally great with super straight sills. To make it totally concours mint it ideally needs a good strip down a full shoot and putting back together, and this is what i always wanted to do. the body itself is solid! the sills are great! (nobody is allowed to touch them with a jack!), the battery tray is totally rust free! Look underneath dash not a thing! inside the battery tray is full of waxoyl, replenished every year!
the main bits that need sorting are replaceable panels anyway. but if someone gives me 3k for the car i will include 2 new unfitted vag wings which is doesnt really need a passenger door and unfitted vag door pillar vinyls. ALL panels obviously TOTALLY RUST FREE!! for 100 quid extra. wings are 60 quid a side alone from vag.
the front bumper is badly faded and could do with replacing! i am sick of back to blacking it!
I cant think of anything else to say, this is one amazing G40 it just needs someone to finish the body work off and it will be even more amazing!! doesn't leak anything whatsoever! as far as I'm concerned its had all the money spent in the right places it just needs some one to detail it!
the grizzly bit...
I wont sell the car to just anyone, this is my baby, if i think for a second your gonna ruin it you wont buy it! that sounds harsh but i can afford to do that! the car deserves to be cherished and driven and enjoyed like i have done, not cut to bits, awfully modified/crashed due to negligence.
if i do sell it to you, you buy as seen you don't drive it home kick its head in wreck it and ring me cos you've bust it cos i will tell you to f**k off! any issues will be confirmed before hand as stated here.
sunderland
Pictures: near the bottom are most recent
with original orange indicators in and back to blacked bumper.
with respect that there are examples that are in better (body wise or millage condition) popping up for 3.5k and bad examples or 'work needed/modified' examples for around the 2k mark i think my price is fair for an original in structurally sound condition with this sort of money spent with 6 months tax, ready to roll. admittedly at this very moment it needs one hell of a clean but nothing a good few hours can't sort, but i don't have time to do this every week when driven daily! but it will be done if someone comes to view.
Price...£2900 no offers.
email spaniel84@hotmail.com
text: daniel 07875718441
Edited by supercharged spaniel
  • Replies 12
  • Views 791
bargain at 2900 mate !
real shame as i have a soft spot for this one good luck with sale !
:D
free bump serious tidy car!
am interested....if you def decide to sell
Edited by neil_dubgt
I'm pretty certain mate but i will have to wait till at least monday when i can speak to the lad with the car I'm interested in to confirm some things. ring me any time you want fella if you have any questions, i'd be happy with someone like yourself having it as i know you'd take care of it.
nice to know you approve :)
what you doing with the plate?
provisionally sold mate. cheers
dan
damn, interested in the plate too.
Free bump for a seriously sweet ride. Wish mine was that good!
well if it falls through for whatever reason it will be up on here. :-D
I can vouch for how tidy this car is. It's structurally sound, any blemishes are meerly superficial. Hope it stays local Dan and good luck with the sale.
cheers. by the way it now has early spec orange indicators back in and original bonnet lift not the chrome ones shown.
pic of the other side a few months back when the charger was being refitted after another fresh rebuild.
i really really wish i had £2900 at this moment in time, because i would be on your doorstep tomorrow.
