Need help removing 16v rear bumper
I have a problem with my rear bumper. I need to take it off to remove a couple of scratches which have come during the season. I have unscrewed the three bolts in each wheel arch, the bolt in the middle underneath the bumper, and the three bolts at the top... It's still stuck as hell! Is there any bolts I've forgotten? If so, where are they located?
  • Views 837
that seems right, what i had to do is stretch 1 side out (from the arch) and pull it as they are on there quite tightly
Thanks, that did the trick! :)
