Air box wire??
I have a 1 litre Mk4 (N reg)
Whilst putting an induction kit on my car my brother decided to pull the thermostat wire off (odviously not knowing what it was) , i dont actually know if its the thermostat wire. Its basicly the wire that goes from near the end of the pipe, it clips onto a circular piece then goes to the air box somewhere,so now i dont know where these two pieces of "wire" go. Cant find nothing in the haynes manual about it, any on know??
  • Replies 8
  • Views 1.9k
BUMP
only 'wires' from that area will be vaccume pipes surely?
yeah that will be a vacuum pipe used to switch the hot/cold flap. if you get rid of the flap you can loose the vacuum pipe, just dont forget to plug it up, else the car will run like sloppy poo due to the vacuum constantly leaking air
Nice one lads, seem to have sorted it now. I wondered whilst i had the induction kit on it was killin petrol. Would this have been why??
Edited by deanwt
How would i go about blocking the hole in the airbox for that wire
Bit of sealent and a tight fitting screw
could i not kinda loop the wire itno the other hole, or would that not work
Easiest way is as carver said, just some sealant and a tight fitting screw, although I never bothered with the screw, just made sure it was airtight.
