bit of bodywork advice please
right the polo needs a little bit of body work and i figure fuck it i cant make it any worse and if i do ill just learn from my mistakes and try again! so...
after spraying what the best stuff to go over it with polish wise? i have been told t cut by some and others have told me there are certain polishes that are better than others i personally haven't got a clue so any help would be appreciated!
cheers
nath
  • Views 1.4k
dont use t cut its crap!!!
what you want to do is give the paint 72 hours to gas off and harden up a bit( the softer the paint is the easyer it makes this )
take some 1200 paper and a bucket of look warm water an flat it back, start with the edges and then do the main part of the pannel.(DONT FLAT WHERE YOU CANT BUFF!!!!!!!)
what you are aiming to fo is when you start flating it will go dull and you will see shing bits in between where the surface is uneven you nee to flat it until it is all dull. just remember through the the more you take of the more likly you are to burn through when buffing!!!!
when this is do wash all the residue of with some paper towel and the water.
if you have a buffer, start with g6 compound and you are aming to buff out the scratches that you left with the paper again edges first!
then after that give it a quick once over with g10 compound which is more like a t cut if you will.
wash it of properlly this time making sure you get rig of all the compound from down all the edges of the pannel ect.. and when dry apply some good polish. dont wax it though you need to let the paint gas of properly first and wax will stop it doing this!!
if you dont have a buffer then i would after the 1200 paper go to a 2000 and then as hard as its going to be you will need to use the g6 just to bring the shine back and then get your arm ready for some seirious buffing with the g10
this is a very simple way of doing it, this trick is take your time, stop and think about what your doing before you do it and all will be good.
the only way this can be messed up is if you burn through the paint!
good luck pal
hope this helps a bit
sorry forgot to say if you cant be arsed with all that then buff the liveing hell out of it with g10 if you are looking for a replacment for t cut and then polish it. the problem with t cut is on fresh paint it's a nightmare to get off it just doesnt want to move
not really on topic no1tosh you seem to know your stuff, i get my car back from the bodyshop later today with the door, roof and bonnet being resprayed. how long before i ca polish?? also am i ok to wash it??? I'm guessing wax is a no too
Why didnt you have the whole car sprayed?
And i'll agree Tosh knows what he's doing,though i cant stress enough how careful you have to be - you'll also have to know what you're doing if you're gonna go to that level,well written as it may be. :thumbsup:
I would assume immediately as the paint will have been cured in the oven before it left the spraybooth, but check with the people who painted it how they reccomend you should look after the paint.
sorry my mistake i thought he was painting it himself and you wanted to know how to finish the job sorry!!
i agree you have to be very very careful wetsanding and buffing fresh paint, i remember the first time i did it and i was bricking it all the way luckly i did it spot on but quite a few times after that i burnt through quite baddly. anyone who says they have never messed it up are talking out of there arse.
i usually do it the day after painting it but that was for two reasons:
1.it was the way i was taught there because they needed a fast turn around
2.it made the job so much easyer.
you have to watch every single move you make and be confident, in no way am i trying to put anyone off i just think looking back i made it sound to easy.
even if its been in an oven it still needs time to gas off properly but no where near aslong.
you can apply a polish yes something like auto gylm super resin or if its a dark colour i personally use auto glym deep shine.
i would give it a good month or so before you apply any wax to it just to be on the safe side.
