mk 3 dash in mk 2
hi peeps converting my mk 2 saloon to a gt I've got the gt door cards in one side(bit of a squeeze) bt went to put the other side in and the dash board is to big, so thinking of putting the mark three dash in out of a breadvan mk3. will this fit because my theory is the mk3 dash looks smaller but because of the door cards being a tight fit it will look jus right any help would be gratefull.
thanks nick
  • Replies 12
  • Views 1.8k
stevie with the mk2 loon has fittted mk3 doorcards witht he mk2 dash iirc he wets them so they are flimsy them remoulds them?
il av a look also will the mk 3 clocks fit the mk 2 dash
is the dash much bigger on a saloon than a breadvan/coupe
It is possible to fit a Mk3 dash but ypu will need some unmolested mk3 doorcards or you will have a gap between the doorcard and the dash .
I will be fitting a mk3 dash sometime in tthe next few months ..
Will be good to see how you get along ..
Stevie
I hear you need the mk3 steering column and supports too, and the wiring isn't a straight swap either.
Still, means you can have a mk3 gt steering wheel instead!
Stevie
knew the leg-end wd be along soon enough :D
hurry up with that dash dude i wan see it!!!
i think I'm gona keep the mk2 dash and try to mold the door cards that is if the gt clocks fit straight in. I have the full car (gt) so can get any bits i like off it get some pics of so far up soon.
nick
Edited by dj_nick
i ran mk3 cards in the front of my mk2 for about 3 years they do give in time but a bit tight to start with
luke
Phoenix fitted a full mk3 dash in his mk2 breader
Piece of piss apparently?
I'm gona try mold them today wheathers shite so perfect I've got my mate cummin tommorow t help with the start of the engine so should be rockin soon.
nick
i've just converted my mk2 to mk3 dash...fits in quite easily, I've made up a few brackets to tighten the fit up a little bit, but its all good. Heater all lines up nicely, swapped all the switches over easily enough. I'll get some pics up when I'm home... I just now need some gt door cards and a mk3 centre console and lower glove box....
.Joe
