Rust and Respraying
My arches are not perfect atm and have had one side sorted last year but it has come back after a pretty shit job had been done on it, so both could do with doing ideally.
I'm thinking about the costs involved in either getting a bodyshop to properly sort them out ie getting rid of all rust and respraying the arches back to how they should be.
I considered doing as much of the work as i can myself in the way of sanding off all the paint, grinding it back to baremetal, spraying it in por15 rust killer, then filling out and having it resprayed.
Just wanted some advice as to this as if i did it all myself i'd have difficulty getting to the inside of the arches where the lip is and sorting it from there aswell.
  • Views 925
my 6n had a rusty drivers arch, rusty drivers sill, rust under the rear light, odd coloured door and sill. i was quoted £420 for the lot.
Ar, Stebbi, you'd be looking at a couple hundred to have it all done, if you're friendly with a bodyshop, i got quoted that for a similar amount of work for mine before.
okidoke, the work i had last time i was quoted 300 for just sorting out the drivers rear arch as most of the rear panel had to be sprayed, and tbh he didnt take the window out so it looks wank and its bubbled up again at the top.
how much is the going rate for this sort of work then?
Not realy sure, its helps alot of you know someone locally, a rough guess would be £2-300.
