some sort of sump guard ?
hi guys, I'm not sure if this should be in here or in "engine,transmission and exhaust".
was just wondering if anyone knows of any sort of guard that was made to cover the underside of you are car to protect the sump and/or gearbox ? that could also be fitted to a mk3, i just thought it might be a good idea to have one, any ideas ?
Edited by jimmy7
  • Replies 15
  • Views 2.6k
you can buy them from VW themselves, it's a factory part. But quite expensive. Alternatively get a piece of metal and make your own,
yeah i was thinking of trying to make one myself, has anyone else done this ? how hard could it be ?
I'm intrested on one also if anyone has any links
iirc gofasterpinch had a link to OMP selling them for rallying... i guess its the same for road :D
i bet there mega bucks though!
I remember yeha telling me a mate of his nailed a roadsign to a sheet of plywood and bolted that under the sump, said it worked fine for a pikey guard.
hmm...baking tray and some cable ties...
^^ hahahahahahaha, was just about to mention one of them :p a road sign or just plain sheet ally I'm sure it cant be that expensive, if you can get a mind the bumps sign and make that work that wd pimp :p
those are some good ideas, I'm totally going to try this, I've got a roadworks sign in my garage ill try to cut to size at some point then work out how to attach it to the car, I'm just worried everytime i hit my gearbox on something!!
you hit your gearbox?
sure its not the drive shaft on the inner arch?
yea I'm going to try this as well duno were I'm going to mount it onto though
i dno dude, i always thought it was my sump but then monkeypolo told me it was the gearbox.
whatever it is, it doesnt sound healthy!!
someone let me know how to attatch this if they try it before i do :D
:D it def the gearbox man!!! if there is one ill have get one for mine!! I'm sure they be same for a mk2!!
lol that would be pritty jokes haveing a "mind the bumps" sign as a gaurd lol
fit a ppp subframe thats the first thing to scrub on mine and not to forget the handeling (sp)
has anyone done this yet ?
i dont know what to attach the sign to lol
you will probably need a bigger bit of ally than a roadworks sighn and you will need to fabricate some brackets
pm gofasterpinch and ask him if he can measure his and post the dimensions of it
then go and "find" a bigger sighn :lol::lol:
