MPG 1.4 16V 6n. On the streets its 21 is that correct?
hi guys
on my polo afh I'm geting around 20-21 mpg on the streets on everyday driving
on the motorway I'm getting around 30- 35 mpg
is this correct or do i need to go get it checked out??
can anyone help me?
hanks
jaypolo
  • Replies 29
  • Views 2.9k
i think 21 mpg is very very low from what I've heard. ill leave it up to one of the experts though.
thats pretty bad my bmw gets more than that
Depends how your driving it really. If you stop starting all the time and kicking its head in, then its expected. But if your pottering about then is very low.
Going from my normal driving style to driving like a granny I saw up to 50 miles extra out of a tank in the Lupo (which is a huge increase when normally I get 200 and I was getting 250!). Its amazing how pulling off smoothly and anticipating whats happening ahead so you don't have to use the brakes actually effects your MPG.
Although I will admit, it does make driving boring and people around you get pissed off with your slowness :lol:
Fuck them though, not like they are paying for my petrol are they!?
yer but low and slow is the way forward :)
my 6n is 1.6 n i get around 38mpg... n thats a mix of in town and motorway miles
I've got into the habit of trying not to have to use the brakes unless really necessary. :lol:
Mines a pretty bog standard 6n Valver and it gets about 34mpg on a combined run...
mine does 36-38 on average
you seem to save a lot of motion lotion if you keep it out of the 4k power zone :lol:
I get a regular 42-44 mpg out of my valver. Thats 1 hour city driving and 1 hour out of city driving every day. And I'm not exactly light footed, can't help but hear the 4k music as much as I can :)
Mine gets about 26 round town, motorways about 36-38.
Average is about 39mpg - best i've seen is 44mpg with no a/c and crusing at 65, worst i've seen is 19mpg with a/c on and seeing over 4000rpm regularly!
Mine's about the same, it's a fair bit better on the motorway though
I could probably increase it by driving more gently but I get bored.
That's bad. I've never had lower than 31 MPG in my GTI thrashing it. And average journeys I do 33-36 MPG
does 250 miles a tank sound about right for a 1.6 bog standard 6n, usually driving between 2500 - 3500 revs arround town and motorways ?
I'm getting about 350 miles to a tank in my GTi that's mostly dual carriageway with loads of roundabouts and a bit of motorway, I'm regularly above the 4000 revs mark too.
i try to change gear be4 3000 rpm to save petrol, but its still drinkin the juice
does anyone no what i could do to save juice, apart frm driving slow?
i put a tener in ova day and I've only had around 30miles out of it, i have been driving fast and slow- mixture around the streets
Get it plugged into vag com and see if your getting any fault codes on the lambda sensor.
Sounds to me like a lambada sensor fault. as said dont waster any time getting it plugged in to vag com as i did and ended up going a month with 20 miles to each 10er. its strongly suggested you fo it.
21MPG...jeepers, I have a 2.4 30v A6 estate and I get 22-28mpg...can get 35 on a long run.
Could be the ol' Lambda sensor issue?
Edited by Tav
I've had a Lambda sensor - not a shite one either, went for a Bosch one, but it's still the same
New VW Coolant temp sender too.
Shit, thats poor.
i get around 150 off £20
At 21mpg id say there is definately something wrong! I get 35mpg from mine, driving in all conditions.
I'm getting about 70 miles on a tenner driving half town half A roads, and i dont go slow either.
Tris did you get the fault code cleared afte rputting the lambadfa on? you msut have non code issues such as exhaust blowing etc me thinks.
