GTO1201.1 Amp.
Have one of these for sale. Sorry its a bit vague but I'm in a rush haha.
Specs:
http://www.dvbcaraudio.co.uk/jbl-gto12011-p-2112.html
""The GTO1201.1 features a high-frequency Class D switching power supply. This topology is more efficient that traditional Class AB designs, drawing far less current from your vehicle charging system.
The GTO1201.1 features a 12dB per octave electronic crossover, allowing you to optimize bass performance based on cabin size, as well as subwoofer location and enclosure type.
RCA low-level inputs.
Full-range preamp outputs facilitate use of multiple amplifiers without the need for noisy and expensive adapters or signal splitters.
A variable bass boost circuit is provided to optimize system response.
Optional remote level bass control available.
787 watts RMS x 1 channel at 4 ohms
1114 watts RMS x 1 channel at 2 ohms, 14.4V
Variable cross-over. Variable Bass Boost.
Speaker Level Input
Frequency Response (–3dB): 10Hz - 302Hz
Overload protection
Maximum Input Signal: 6.1V
Maximum Sensitivity: 140mV
Output Regulation: .21dB at 4 ohms
Dimensions (W x H X D)
Main Unit: 18-11/16" x 12-5/16" x 2-3/8" ""
I'm after £100 collected, WS3 5AZ
Or DubClique meets, www.DubClique.com for the postcode etc.
Thanks.
James.
07896968014
Edit:
Can be taken to polo show, but i need money asap lol, so would prefer to be collected.
Edited by jamesu1990
  • Views 324
Popular Days
Bumpyyy
Offersss?
