Door
I know there have been many threads about water gettin in through doors, is it beacuse I've got the door cars off my mk3 genesis? took them off as was going to replace the window winder mechanism on the n/s tmorrow and its been raining all tday? water is dripping in from inside the door.
  • Replies 10
  • Views 1.6k
you disturbed the door seal itself?
I did take the door off with the upmost care, and I'm sure it wasnt leaking before. water looks the be running down the inside of the door and then dripping onto the carpet and into the footwell.
as you have taken the door card off u sure u haven't knocked the window winder a tad?
The winder mechanism is broken so the window neither goes up nor down just grinds when u turn the handle. could it be the window seals hence how its getting inside the door?
Most likely your door top window seals letting the water in. The door will drain a little water itself and the plastic sheet will stop rundown getting through to your doorcard and wrecking it, bu if a lot of water's finding a way in, it won't be able to drain it properly.
Water leaks into the door of all Polo's,most cars. Its supposed to.
It then runs out the drainage channels in the bottom of the doors,held from dripping into the interior by seals behind the door card - that you/someone must've removed.
One is the big plastic sheet,that covers the inner door skin. You have to peel this open to get to the window mechanism. It must be re-sealed afterwards.
The other is a small flap in the corner,which allows air out (via the grille in the door),but acts as a splash guard preventing water getting through it from the other side.
Both these must be in place,otherwise the back of the door card will get wet,and water will run down and leak into the footwell.
I have found the problem...
Sweet it will all be good tmorrow if the weather clears up for me to fix the window winder, haha ill make sure to put the door on with the up most care to :-p .
