280mm brake kit discs and pads worn calipers b/n last year
i recently bought back my mk1 golf gti and after much thought am breaking alot of it........
this ad is for the 280mm brake kit consisting of worn discs and pads, 1 year old calipers and the spacer plates to move caliper out
looking for £120 collected and am not looking to post
all are still fitted to the car and in working order
call or text olly on 07789 18 48 58
  • Replies 8
  • Views 682
i take it these use standard 6n hubs and not the 16v ones ?? if so i maybe interseted ! as 16v hubs seem very hard to get hold of for this conversion !
16v hubs are the only ones with bolt on carriers which is a must have for larger diameter discs, all other 6n's run solid carriers which make it impossible to increase disc size.
not sure where you're from but my local breakers have a couple in which would be suitable....
same problem as i have :(
maybe i should go down the breakers and get some valver hubs and put it all together as a full conversion kit but would obviously be at a cost.....
calipers for big brakes (280mm) were standard and sold.
adaptor plates with worn drilled and grooved discs £80, fit gt's and g40's too apparently!
you need minimum of 15" rims to clear these brakes.
hey mate is hte anyway i could get theres 2 fit on a mk3 polo g40 ????
as far as i know they bolt straight on as daveg40 sold his ones from his g40 to a mate of mine and we fitted them to a mk1 golf.
