pink flakey shizl :/
Sorry to post this in the general section rather than search or look for the relevant section, but iam in a bit of a hurry as the item ends in an hour! (ebay)
I've been to look at a couple of Polo's today and theres a pink flaky type stuff down the right hand side of the engine on quite a few of them. Now i am 99% sure its coolant. The only thing i can come up with is that perhaps the polo engines used the same crappy plastic flanges for the water hoses as some of the golf engines, which were prone to cracking/leaking, or is there a more common problem iam not aware of? is there any sort of overflow pipe that terminates in that sort of area?
The engine will be getting replaced sometime early next year, but i could do with use of it for a few months beforehand! any ideas?
-D
  • Views 784
my gearbox is covered in "pink flaky shizl" because the pipes are starting to perish a bit. nout to worry about.
well it's coolant and means coolant is leaking out. Needs sorting out really it'll only get worse
its cos i put too much in when i changed it
"pink flaky shizl".. is a technical term btw:P lol
