Who can powdercoat split rims in Suffolk/Norfolk?
Hi i've just bought a polo gti with the bbs split rims and need to get them powdercoated as they have gone bubbly.
Does anyone know were to get them done in Suffolk or Norfolk that will do split rims?
  • Replies 8
  • Views 1.5k
you need to strip them then get them sanblasted or even better glass bead blasted ,then get them powder coated and re asemble, but you will need new bolts to reasemble them safely and you may need a special splined tool to enable you to strip and tighten the bolts in them what you will need to get from bbs,
buckenham bead blast in ellough did a great job on mine.alsomareocoat but there quite expensive
Will buckenham powdercoat split rims though? Cause i thought they would'nt.
Aerocoat said they probably could be able to so gonna see them on Saturday
split them yourself all you need to buy is a m8 spline bit cost me less than a fiver. then when you resassemble locktite the bolts and use a torque wrench to the correct setting. will save you lots of money!
Where can i get this spline thing from?
I know a guy that can do them near cambridge,. Brilliant results as he airbrushes them all he lives in Chatteris near Wisbech which is in Norfolk. Drop me a PM if you want to contact him.
aerocoat in st. olives. (in between yarmouth and beccles) are real good
