Removing 16v frontbumper
I'm trying to remove the front bumper on my 16v Polo 6n. But it's stuck, somehow. I've removed the grille and the plastic-thingie which is located under the grille and the lights. Also, I've removed the three bolts in each wheel arc. The two bolts behind the grille in the bumper are removed, and the two bolts in the splitter are taken care of. Which bolts have I've forgotten to unscrew? Help would be appreciated! :)
  • Views 1k
haynes manual..... but have u looked ALLLL the way around the grille holes, there always seems to be one you miss :p
Haynes is gay, only covers the regular Polo, not the 16v :( Have that, and it really isn't any help... Hm, will have to look again tommorrow ;)
Had missed the screws located to the side of the foglights. :)
