Rear Washer Wiper gives no wtaer & Roof Lining Leaks
Hi Mate
I have two questions which you probably know the causes of or I hope you can point me in the right direction for some information:
1) I have a water leak coming in fom the end of the roof liner near the edge of the Windscreen Black Plastic Seal. It only appears to leak when the car has been standing still for a while and with a heavy rainfall. The water falls onto the Rear View Mirror and hits the Gear Stick.
2) My Rear Wipe Washer does not work. I placed a needle into it and can hear the motor wokring but it does not help. Would it be due to a rook connection.
Thanks for the help.
Sunhil
  • Views 893
Popular Days
Which model polo is it? The Mk4 polo's rear wash tube often comes apart just behind the rear seats where's it joined. The pipe runs down the left hand side of the car and the joint is behind the where the rear seat latch is. Push it pack together and put some zip ties on either side.
