1341cc G40.
Good work mate, I've been working on my own wiring again this week - it is just a pain as it takes so long - and you cant skimp or you will get running problems - hardest part for me was sorting out a longer piece of 3 core 0.5 for the knock sensor. you should get down the scrappy and get the newer end pieces and rubber grommets for the connectors - makes it look soooo much better:-) worth doing it now while your in the process.
and I'm sure you know already but to make sure you dont make a c0ck up - the ECU vacuum hose is a set length and can not be extended- you will need to make a hole in your heater hose grommet;-)
And wire 6 from the ECU is a thin earth which supplies 4 earth points on the engine - worth uprating this wire to a thicker gauge then standard - this is the wire known to be a problem point as where it joins is a clamped not soldered joint.
Good luck, I've enjoyed reading your progress
KiZ
  • Replies 97
  • Views 26.8k
  • Guest vwmk3jon
    Guest vwmk3jon
    I've wax oiled all my arches and will start on painting the beam when it gets back. I know what it's like to never be finished! Lol
  • It's painted..and home!
  • I bought and renovated a house which slowed things! Then a big turbo lcr project!    I'll update soon! I've done a few bits
this car has made my pants wet with joy!
This is the kind of shit that I really like, nice one on the attention to detail mate, it will definitely pay off!
Cheers guys, not touched it in a couple of weeks as bought a bit of a bargain S3 and have been sorting that out!
Thanks for the comments, does keep me going!!!
Kiz, Good points, totally forgot about the vaccume hose tbh!!!
I know the earth, might well do that, supplies the Blue temp, dizzy etc iirc?
yes the earth supplies the dizzy, temp sensor, VAF and throttle switch. its a bugger when it starts to go.
i wonder if the 0.5m vacuum length can be extended all be it with a remap???
keep us updated
Ah cool I know.
I have failed and have not touched it lately.
Bought a S3 for a months money basically with a minor running fault, which is now up and going so soon back to the polo!
You are either on some top wages... or that was one stupidly cheap S3 :lol:
Total porn - look forward to seeing more of this 8-)
Cheers chaps.
Yeah was a baragin, had to trailer it home and fix a fair few niggles mind, dunno what to do with it mind, pretty juicy even compared to my 1,8t A3.
Polo Engine may go back in tomorrow!!!
  • 6 months later...
ressurect?!!!!!
nice, like the bay!!
Cheers. Got Xmas on this!
bout time!
Is loads more advanced than in the thread! Engine in and running, rear beam off and powdercoated etc!
PICTURES!
PICTURES!
Sorry no bay pictures... as all covered up..
However been busy this evening, been scrubbing..laborious!!
Light provided by Screwfix + Audi S3!
Has come up pretty well, wipe down with Panel wipe and then time for the epoxy mastic.
Here's the rear beam, blasted and powdercoated, all built up apart from bushes (left em at work!) and caipers as need banjo bolts etc.
More soon...
Love how much work is going into this, you keeping 'the' wheels for it?
The pic of the G with its arse in the air is cool!
Awesome!
i remember doing mine - i didnt have the luxury of doing it like that tho - i had all 4 wheels on those 10" high drive on ramps and used a car crawler to get under and spent hours scrubbing so i know how much work has gone into that!
worth it tho when its all spanking and youve sealed all the gaps up so rust wont be back for years:-)
Thanks. Yeah a ridiciloius amount!
Update,
Spent most of the day working on the underside, fully degreased and primed..
And Epoxy Mastic applied!
Next up is alpine white 2k gloss, when that has dried a bit!
Haha fook!
Good work there bud :)
Amazing!!
This will be up there with the best when its done :0
Will be the best!! Maybe lol.
Gonna buy some coilovers I think, so they match!
I would be a shame not to use coilovers on this.
