what wiring kit guys ? :) cheers!
Alright guys I've fitted the headunit today no problems there, i am totoally new to the whole ICE scene etc and i have a alpine head unit, and a jbl 4 channel amp. I've linked them below so you can see what I've got exactly. The speakers I'm going to buy will be the Alpine ones many of you linked in the 6.5 section i asked about. I have no idea on what wiring kit i will need as it stands i just have a head unit with amp no wires came with either cheers guys!
Headunit-http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200251883263&ssPageName=ADME:X:RTQ:GB:1123
Speakers ( I'm going to buy) -http://caraudiosecurity.com/shop/product/products_id/5323.html
Amp- http://caraudiosecurity.com/shop/product/p...ts_id/2911.html
If anybody would be able to fit these 3 for me, please let me know a price thankyou :) I'm a CV11 postcode!
  • Replies 10
  • Views 1.3k
I bought the autoleads amp wiring kit form halfords about £30 it is. Mind you'll need some extra speaker wire as you only get about 2m of it, and also make sure the kit you get is the correct one, meaning the watts.
My mate bought a fusion 1 from halfords. All went in a piece of piss had everything you needed. I just sourced all the wire i needed from work though. I can sell you a mean bit of earth cable for a few pennies if you want.
=D well yeah ide buy it :s i just dont have a clue what wiring kit i would need for the components listed above anybody help me please :D cheers!
Anybody help me please ? *bump* what wiring kit cheers
the amps a 4 channel right? so are you wiring a sub in there aswell?, or just the components, cause the components will only take up 2 channels, even tho its effectively 4 speakers
You need some thickish power cable with an inline fuse holder wired in. Then you just need audio cable and an earth cable. And some smaller gauged wire for a remote wire.(turns amp on and off with ignition switch)
ahhhh, didnt realise you were the same guy in the 6.5 advice topic, (glad you got the alpine ones) anyway, components consist of 2 speakers, and a splitter, that splits the audio signal, one speaker plays the higher frequencies, and the bigger speaker plays lower range, , both these speakers connect to the box that split the signal, and then its just a single wire job
so youv got (+/-) (+/-) from the speakers going to the splitter, and then just (+/-) going to your amp, so thats how ull have essentially 4 speakers only using 2 channels,
the wires ull need, will be ,
1 red, power wire (fused)
1 ground (black)
1 remote turn on wire
1 (2 if you want a sub) rca audio wire,( looks like the red and white ended leads that go into you are tv)
and possible standard speaker wire depending on where you are gonna mount the components, ( iv got them in the front, and needed extra wire)
http://caraudiosecurity.com/shop/product/p...ts_id/8458.html
something like that should do it
Edited by chrisbin
look good mate, tho you'll wonder why there's all this hype about components, and you'll only know when you get them,
so you getting a sub to use those two other channels?
Well buddy for the other 2 channels when i get my polo gti at the end of the year! :D I'm getting 6x9's on the parcel shelf! :D sub comes then just with another amp =D
