retrimming interior pillars and roof
hw do i get the roof lining off?
hows it attached?
and also how do i get the pilars off?
are they clipped on?
also there is a cream grey seal that goes over the door. but i need it black.
how do i go about doing that?
thanks
shaun
  • Views 1.2k
I've seen a guide for this somehwere i think, might have been for a lupo? not sure, probably similar though?
I think its screws and clips under different plastic bits?, dont quote me on it though
oh right ok.
any one else got any info on this?
gonna do this at the weekend.
cheers
shaun
and dude find that guide.lol
headlingin removal. remove all your visors and grab handles, usually screwed up. then go in the boot and the first bit of trim across the opening pull down (with force) and it will come out from the rear pillar trims. then its simply a case of pulling rear pillars off
b-pillars require removal of seatbolt (17mm socket/spanner) then a case of pull and there off and similar for a pillars then headlingin will drop out may need a pull as there usually glued along the windscreen
any good?
oh rigt cool. wil black vinyl look good on th pillars and that etc,, the plastic parts
then i dont know what to do about the roof lining and visors.
what you guys think?
cheers
shaun
cheers
shaun
I've seen something about this kinda fing on t.v. b4 i think, they used black paint in a rattle can, presume it was fabric paint or something to make a grey parcel shelf balck so it would probly work on the roof lining!? let me know how you get on with it m8 i want my roof lining black as well.
rick
not doing my roof black, thinking of doing my pillars and that black vinyl.
and the mirrrors black and then i wanna d something good with the roof.
checkered?
