huge water leak polo 6n valver
HELP! the other day i found a huge puddle of water in my car i have taken the carpet out and pritty much all the interior! with the hose i have managed to track it to the passenger side window seal which 2day i have just fitted a new one at a cost of £60 and guess what!? STILL LEAKING! you can see were i have removed the doorcard the water piss's in! but the seal to the window is as tight as it can be!?! so confussed.com! so please anyone that can help me please do! I'm desperate! thanks for your time Ash :crybaby:
  • Views 1.6k
What about the grey waterproofing foam behind the doorcard is that all intact?
have you checked that the drin holes on the bottom of the door are blocked ?
that would cause them to fill up and flood your interior
yeh have checked drain holes but after a closer look the foam is nakerd! dohh!!! were can i get new stuff from?
You need to check your pollen filter. Probably blocked up with leaves. Look under the scuttle panel on the passenger side!
Check the pollen air filter mate and drainage pipes
a good car audio shop or the scrappy
cheers for help guys problem sorted! got new parts yest and seems gd as new thanks! :-D
