Filler Question
I have a tiny dent in my roof which needs filling...
I was looking to purchase this
http://www.jellydeal.co.uk/upol-easy-sanding-body-filler.htm
What I wanted to know was whether I needed to purchase Hardener separate in order to mix in?
  • Views 1.4k
hi mate easyone by upol is the stuff i buy at work and it comes with a tube of hardener and a spreader
hope that helps
tosh
hope that helps
tosh
Thank you
If it is only a small dent, you might as well get a small tin of white stopper. I use easy 1 filler to fill in major dents and for shaping. Stopper is much easier to rub.
Can i get a link for more info and where to buy?
your best bet is to google it or go in your local body shop and ask them if they would order it in for you. it might work out cheaper than going to halfords. Or be abit cheeky and ask them if they would let you have some, just enough for your tiny dent. I'm sure they would. If you came to the body shop i work in, we would give you some, no problem.......
where abouts are you?
if youre local you can have a bit of mine, save you buying some
