Powerful enough?
I hope to buy this sub eventually, does anyone know how good it is?
Ebay Item number: 300256981661
Also do you think that this amp will power it okay
slick a2
or it's this if not
Slick a3
Cheers.
Edited by H@wK£R
neither of those amps are any good for your application
the sub is 1000 rms you need and amp that will give AT LEAST 1000 rms
the amps you are way not powerful enough
it is always recomended to give a sub too much power
you might want to try this amp
http://caraudiosecurity.com/shop/product/p...ts_id/8046.html
Sorry i got maxx watts on the amps mixed up with the rms :lol: of course they'll be bad i think i'll give that sub a miss and go for something less powerful, anything else in the vibe range you'd reccommend as a sub?. cheers.
This sub would be perfect wouldn't it with the A2 amp? or even the 15'' version. Is this sub good i heard someone shot the speaker versions of it and it didn't pop it.
if your looking at this sub an are having problems with amping it, why not have a look at the active ready boxed version.
Vibe SQ12 Active Evo V1 (its fantastic!, i fitted it to my 6n an can only run it about quarter power, otherwise i think my ears would start bleeding!)
