spot the differences
wasup boys and girls.
abit of a newbie question but I'm new to all this polo game!
what is the fundamental differences between a standard mk3 polo and a gt? annnnnd how hard and how much would it approximatly cost to convert a standard mrk3 to a gt???
excuse the ignorence haha.
niki
  • Views 972
GT's are MPI, different gearbox, Cam, ECU - Digi etc. The difference of either 45bhp (1.0) and 55bhp (1.3) compared to 75bhp.
Putting a GT in a Mk3 is 'Easy' - I'm using '' because i have not done it myself, but people that have say its a simple conversion. Oh and get some GT clocks so you get a rev counter.
Depends on the model..
Main differences on the GT over the other models (accept G40)
Interior - sports seats, rev counter, steering wheel
Exterior - Arch trims, sill spats, red pin stripe in the bumper and the obvious badges.
Engine - 75bhp MPI as Kerrly said with a short ratio gear box, higher lift cam, high er compression bottom end and digifant ECU.
Brakes - has a rear load compensator, which does pretty much fuck all.
Now, there are some 'genisis' special editions which are basic polo's with a rev counter and GT/G40 steering wheel.
Also there is a 'NZ' engine which is a basic 1.3 polo with MPI but only 55bhp, some people say its 65. This has a lower compesion ratio to the GT, taller gear box ratio's, smaller lift cam, smaller inlet mannifold (but same as G40) and has a digijet ECU.
Conversions are really easy if your good with cars. Uses the same mounting points and the engine loom is plug and play. All the interior looms are the same.
Edited by MrP
thanks for that dudes
