wobble bolts and spiggot rings
where can i buy some?
I've just brought some superlights in mini fittment and i need these to make them fit
its for a mk3 polo
cheers
  • Views 1.4k
anyone?
Any local alloy wheel shop should sell them both.
I got my wobbles from there..
Spigots for 13's.. might be better off ebay, just search spigot rings, i got mine special order for my Alley Cats.
Chris.
cheers dude
you do need both to make them fit right?
how do they work?
The holes on your hub are 100mm apart diagonally, Mini's are 101.6mm, so cause the holes are offset, you need wobble bolts, basically the tapered part at the head of the bolt, is loose, so as you screw them in, the 'wobble' into position.
Screw them a in to a pinch, to get them located properly, then tighten each one a bit at a time. You can get away with 3 per wheel you want to use locking bolts, like i did.
Spigots, metal or plastic, are basically jsut a kinda spacer/washer, where the centre of the wheel sits onto the hub of the car, VW's is 57.1mm, the Mini ones are like 65mm IIRC, so you need the spigots to make the wheel fit on snug, and not wobble around.
ohh i see
i never knew quite how they worked
so i only run 3 bolts?
http://i173.photobucket.com/albums/w74/mk3...pictures044.jpg
these are the wheels i have
and you say that local car spare shops will do both spiggots and wobbles?
cheers for the help mate
sorry to be asking so many questions lol
i haven't got a clue
No worries lol.
Use 4 wobbles, but if you want locking bolts for security, its safe to just use 3 wobble and one locking bolt per wheel.
Wheel shops should sell the bolts, but none i went to had spigot rings for 13" wheels.
Best bet would be the 'bay, you'll need to tell the seller, the internal diameter is 57.1mm, and then measure the centre hole of your wheels, and thats your outside diameter. should be 65mm but i'd check just to make sure.
Cost me £1.50 per woble i think, and £11 delivered for the spigots.
Chris.
