Polo GT - 256mm Brakes, G40 Interior, etcttc
Hello hello, time has come to part with my GT, will be 21 as of 20/10/2008, so its time to insure my recent G40 purchase.
This is available from 20th October!
I bought the GT in January, and it turned out to be a bit of a shitter, (was dark ok..) since then, I have replaced large numbers of parts, and now it is running sweet.
Make:
Volkswagen
Model:
Polo GT
Year/Reg:
1991 - H
Mileage:
Engine circa 80k, shell unknown.
MOT:
May 2009
Tax:
Will be sorn.
Good points:
Has received a pretty extensive restoration when I purchased it..
Engine
Lower mileage replacement, which in the last 20k has received, a top end rebuild, new valves, guides, stem seals, a skim and a headgasket, receipt for work.
Before it was put in 7k ago:
  • Cam belt and water pump
  • Cam belt cover
  • inlet gaskets
  • exhaust manifold gasket
  • sump gasket
  • camshaft oil seal (vag)
  • Aux Belt
  • Engine mounts
  • Gearbox Oil
  • Blue Temp sender
  • Black temp sender
  • Thermostat
  • Plugs
  • Leads
  • Dizzy Cap + arm
Modifications/upgrades
  • Raceland 4 Branch
  • Polo Ace 7.3k Chip
  • De-wedged throttle elbow
  • Pipercross kit
  • Charcoal canister removed
  • Phil J straight through midbox
  • Phil J single exit 90mm rear box
  • De-cat
Brakes And Suspension
  • Bilstein kit
  • Gladersite Arb Blocks
  • New TCA's
  • New Flexi Hoses
  • Some copper lines
  • New Shoes
  • Wheel Cylinders
  • Adjuster wedges
  • 256mm Brembo disks
  • Vauxhall Calipers
  • Shoulder Bolts
  • New 22mm Master cylinder
  • Fluid Changed
  • Cleaned and painted calipers
Wheels and tyres
  • Toyo proxies, 195/45/14 - 7k old
  • MK3 Golf steelies
Shell
Brilliant black, L041 I think, pretty tidy, some stonechips and carpark dings, but no accidents/panel gaps etc
  • Late Spec Clusters
  • Clear Indicators
  • Clear Side repeators
  • De-wipered
  • Badgeless Grill
Interior
  • Full G40 Interior, I'm good condition, I
  • Blue Led's in dials
Bad points:
Have welded the battery tray up, but its not perfect, gear linkage is fully functional, but worn, but only averagely so.
If I was keeping it, I would change the suspension on it, it has a bit of a negative rake atm, but I do have some FK springs I may put on it. Would also put something dishy on!
Buckingham, MK182NU
Pictures:
Price:
£1050, not looking to accept much lower tbh!
Wouldnt mind keeping the 4-branch, so offers too!
No swaps!
Contact details:
07707388953
Cheers - Rich
£850 without 4 branch!
Edited by rich4130
  • Replies 23
  • Views 3.6k
might be interested got any pics? in process of selling my car at the mo.
how about a swap for a rocco 1.6gt??
Bump - Pictures!
Bump, will accept offers without the manifold etc.
i will be able to buy the car from you on the 20th of october for the full asking price
very interested mate just need to sell my car will let you know
Bump, This is for sale as of now.
I will be removing the stainless 4 branch manifold, will come with standard downpipe/cat.
Will come with a sony headunit and 6by9's.
Few niggly bits, Rear parcel shelf support has cracked, is supplied with replacement.
Has mismatching side repeaters.
Cracked rear lens
Boot lock needs replacing
Exhaust could do with a couple of new rubbers.
Will hopefully get some of that done asap, can then be viewed.
Also has a sigma alarm and immob, and remote central locking, with keyfob
Want around £950 for it.
Rich
Edited by rich4130
Do i spy mk3 golf indicator and wiper stalks also ;)
Yes you do! Much nicer than the clunky polo ones.
Buuuumpppp. Can be viewed.
bump.
bump, offers?
Really don't get why I'm getting so little interest, properly sorted little GT, I spent an absolute silly amount of time and a fair few quid replacing virtually every part which can wear, will be going on ebay soon if I don't get any interest, I need to pay my G40 insurance off!
Tis also taxed so can be driven away, has been 100% reliable in the 10k I've done it in.
Rich
Edited by rich4130
£750 with the branch.... :thumbsup:
Too low really mate.
£800 with the branch.... ;)
I'd accept that without it!
bumpp
YHPM :)
bump
Bump 800...
Provisionally sold, due for collection saturday.
Solddd:)
